BeepBeepRR
I just spent the entire day yesterday dropping the trans back out of the roadrunner to replace the input shaft seal in a hughes performance transmission. Thinking it was leaking there it doesnt leak when the car is running or for about an hour after its off. But you come back to look at it in the morning and there is a puddle on the ground. When I dropped the trans yesterday the pump seal seemed to be good to go with no leaks. I also installed a B&M torque converter when I initially put it together. I noticed the new converter came with a new seal. My thinking was that it must need that seal to work. So I dropped the trans yesterday to put that seal in. All was well but came home from work today to see a new puddle under the car. Its coming from the front of the transmission.
I am a little pissed at the moment because the exhaust H pipe runs just behind the trans. In order to drop it I have to take the entire exhaust loose from all the hangers just to get the trans out of the car. If anyone has any ideas as to why this thing is still leaking please help a man out.
New Hughes Performance 727 with deeper than stock pan.
New B&M torque converter.
9 quarts of trans fluid.
