Bb70charger500
Guys I am driving the 72 440 4 speed charger I normally don't get on it but I decided to last night . Anyway light throttle it's fine heavy throttle it is pinging like hell! Then to add to its issues it diesel s when you cut the key off it won't quit till you let off the clutch in gear !
So I'm assuming timing is off but wanted to check before I start playing with it . I didn't build this motor don't know much about it except it is very low miles !
Am I on the right path what should the advance be on the 440 motor?
