Pinion Yokes - What to Use
I have a 1350 yoke on my diff and a split joint that’s solid. When the shaft gets replaced it will be all 1350.
Currently, I have a 741 case (3.55 w / cone style LSD) and a 742 case (3.23 w / clutch style LSD). Both have small yoke. I do have a 3.55 gear set for the 742, which I would have to swap to use with current trans setup.
The nice thing is both the 741 $ 742 use shims to set bearing preload... So you can swap the yoke without effecting the bearing preload... 7290/1330/1350 all are an easy swap...
489 uses a crush sleeve so swapping the yoke can be a problem... To do it right you need to disassemble the axle unless someone has swapped out the crush sleeve for a crush sleeve eliminator...
That's why I asked which housing he had.
