moper
You need at least a true 10 to 1 to get decent torque/horsepower.
Nah. It just makes it easier.
If you use the , you can input all your data, and get to the C/R you want. I'm getting you at 8.6 to 1, at best. Those heads may be closer to 88 ccs. And if there are valve reliefs in the piston, you have to add that to your compressed volume. Some KB pistons can have 4 to 7 cc of valve relief. You need at least a true 10 to 1 to get decent torque/horsepower.
Nothing wrong with stacking shims. Check any race head and I'm sure you'll find spring shims. Mine runs 320lbs on the seat, 820lbs open with stacked shims. What is most important is that you have the correct spring for the cam. Do you have new springs? Or have you pressure checked the ones you intend to use? How did you measure the head volume? The biggest issue you will see with unequalled stem heights is the ability to get proper lifter preload without resorting to adjustable valve train. Stem height difference of .030" should be ok, but I'd check it. A bent piece of Mig welding wire between the lifter snap ring and lifter piston will tell you. Test with .023" and .045" . It should ideally be in between those 2 sizes.
Doug
I have used the 260 comp cams unit back in the day on a 72 low compression 400 engine.
The A-Hole neighbor to the west of me already called the cops on me! (Didn't help the car backfired like a bomb going off in front of his house) I mean damn, I had it home for just two days and I'm already getting in trouble with the law! lol!
Sounds like the secondaries are running way rich. What kind of carb? And don't worry about the neighbor, sounds like he has no sense of humor, or knows how to have fun! Prob thought you were doing a drive by! LOL
