XMAN JR
I finally got to work on my dads 62 polara. I adjusted the shift cable. It will not start in any gear but neutral. I had the pan off & shifted it in all gears & it seams to be going into the gear that I put it in. I thought I had it. So I put the pan on & put trany fluid in it. When I got it started I noticed that the speedometer was moving. (driveshaft off) I looked under the car & the trany was moving. I don't under stand what going on. My dad didn't get the chance to school me on the push button tranys. They only thing we got done was we installed the shifter cable. I tried adjusting it several ways. Hold the low button, hold the reverse button in, the last one I did was I held the neutral button & adjusted the cable that way. Every time I went through the gears & ended with neutral I got under the car & looked. It always ended up on top of the neutral safety switch. My dad always said it was one of the easiest tranys to adjust. What a im doing wrong ? You know I never gave this a thought. There is a reverse manual valve body in it. Would that make a difference ?
