5.7, there's nothing at all wrong with the ductile iron rockers and I would recommend them and a couple others on damn near any rebuild other than a stock rebuild, BUT,on your stock rebuild was the block decked? was the heads resurfaced? Was the valves and seats reground? what was the old head gasket thickness? what is the new head gasket thickness? See where this is going and now were going to slide the new hydrolic lifters in and what has changed deminsionaly on those. They say just crankem down basically and they will self adjust hydrolicly and all is groovy, right?Now lets talk about oil, is it new or old? is it multi viscosity or straight viscosity? synthetic or dinosaur squeezins, hot or cold, 10 wt. or 60 wt.. dirty or diluted and what is the oil pressure range in PSI on said enginefrom idle to 6 grand and how does these good many discrepencies effect on the majical hydrolic lifter with the do all MARSHMELLOW trapped inside keeping the entire valvetrain timed and adjusted to near perfection, IT DOESN'T for me. And OH, I must have forgotten the pushrod length to this frenzie also. So here it goes, I'll say it, I like and always use SOLID flat tappet lifters and or Solid rollers and ADJUSTIBLE ROCKERARMS for ADJUSTMENT PURPOSES. Starting,base and overall timing, idle,jetting, running temperature and higher RPMs will show easily the results. Basically a **** load of tuning will be left on the table with hydrolics except for mommas grocery getter. Good luck to all solid and hydrolic.
