Small arc, when reinstalling positive battery cable?
koosh
12:42 PM
CT
I been noticing whenever i remove tbe positive battery cable to work on electrical issues, when i go to reinstall positive cable, i get a small arc, which i believe means something is drawing current?
Nothing is on in the car, gonna need help on how to find it?
silly question.. are car doors open?? interior lights maybe ?
Pull one fuse at a time until it stops. If you have Multimeter that can read DC amps, pull the fuse and place a lead on each of the fuse holders (series) until you find the circuit that is drawing curent and then go frim there.
You should always remove the ground cable first and hook it up last.
Do you have a working horn? If not, the button in the wheel can make the horn relay pull in constantly.
So a slight draw with apparently nothing on.
I DO have aftermarket radio, and amp, but they are not on unless key is on?
They draw a trickle for memory. One wire is hooked to a constant hot. Another to a switched hot.
Horn works fine.... (aftermarket steering wheel, new horn button, and new signal light harness)
Im gonna have to get one of those...my meter only reads voltage and ohms
They draw enough for a small arc?
Any draw can. Disconnect that hot wire and test again. By removing the ground cable at the battery first and hooking it up last eliminates arcing.
Thanks!
On a neg ground system elec flows from neg to pos thru the systems back to ground. The elec supply is stored in the battery. It cannot flow from the battery until the ground is hooked up. When you are hooking and unhooking the positive first you are playing with a live circuit midstream. By hooking and unhooking the ground first you are working before the power source and eliminating the arc.
Thanks a bunch!
the reason being that you unhook the negative first is that the body is use as ground. so if you have the wrench in your hand and you touch the body nothing happens
but image your unscrewing the positive and you touch the body you can cause a huge spark and melt down
Separate audio amps and the radio's have capacitors in them that charge up when you first connect power, they can cause a small spark when connecting a battery back up even though they are turned off. The thing to check is how much current is being drawn constantly off the battery when everything is turned off.
The clock/memory in the radio should only draw a few milliamps. if its above 40-50 milliamps you will need to start pulling fuses and disconnecting things to pin down the draw. Main thing is if you car will crank just fine after sitting for a month or 2 its not a concern, However, if you know the car is going to sit for more than a month either disconnect the battery or better yet is to disconnect the battery and connect a small battery maintainer to keep it charged no matter what the static draw is off the battery
Agreed! Great advice!
