bigmanjbmopar
Newb with a view
Ok, so I bought a red 36 tooth gear and had it put in on the rebuild, they took out the green 31 tooth gear.
Story - with the green 31 tooth gear speedo was 5 mph fast so at 65 speedo read 70.
did the math with the calculator. 3.55 gears 26.57" tires comes up as red 36 tooth gear.
Now my speed is mph slow?? so now at 65 speedo reads 60? confused on which way to go up or down? go in between?
Also is it possible to have 3.54 gears in a 8-3/4 with a 489 case? I thought the 3.54 only came in dana 60's?? I ask because doing the hillbilly check with both wheels off the ground and a tyrap on the axle and tape on one wheel I got around 3 rotations from 54 or so drive shaft turns it was close, I just want to believe I have 3.55's someone tell me i just counted slow or something?
from mymopar.com
from mymopar.com
Speedometer Gear Selection Guide | ||||||||||||||||||||||||||||||||||||||||||||||||||
Please Note: These part numbers are for the standard style pinion gear. The last two numbers of the part number is the number of teeth for the gear (Example 2538943 = 43 teeth). Here is an example on how to calculate the wheel diameter to select a speedometer gear to use with the desired ring/pinion gear.Tire Size: 245/60/15245mm/25.4mm = 9.64 Inches Section Width9.64 in. X 60% = 5.79 in. Side Wall Thickness5.79 in. X 2 = 11.57 in. Total Side wall height11.57 in. + 15 in. (Rim Size) = 26.6 in. DiameterSo with this Tire Size and 3.91 Gears, I would use a 40 Tooth Speedometer gear. |
