Starter clicks despite 12.4v.
Geff McCarthy
7:15 AM
Portland OR
i have charged it, and whacked on the starter. The flywheel may have a broken tooth, but it has only refused to start once before. New aftermarket starter. Any hints appreciatged!
check all connection, I had a bad connection on my ground posr at battery. Chased it for a couple days,it looked clean. :BangHead:
Starter switch
Starter solenoid
Cable corrosion inside, poor crush on ends. Lot junk out there. Internal connection. inside starter stud is a copper washer that wears on stud side causes a bad connection. Take starter apart and flip over the washer, if the stud is beat up may not work.
Its not unusual to get a bad starter these days. I had a starter for my Roadrunner that was not engaging completely from day one and eventually didn't engage at all.
Then recently on my 2022
ram 3500 had a starter quit completely at 12000 miles.
Just hit it with a booster pack AT the starter and drop the guess work. It's that simple..
Sounds like a bad connection or bad cable. Could be either positive or negative.
I had a bad ground cable that acted the same as what you are dealing with.
Did you figure it out?
i put it on the charger overnight, and...no problem! Thanks for advice; I think I will try a proper diagnosis if it acts up again.
Any updates? Did you find the problem?
