Suspension suggestions 69 Road Runner
pro-streeter
4:46 PM
Spokane wa
I need your suggestions. I want to reduce weight and improve handling. I don’t want to relocate any mounting points this includes the upper shock mount. I am ok with a suspension that eliminates the torsion bar, however every other component needs to mount as the factory does. So far many of the k frames relocate the shocks upper mounting position.
It may be the best way to achieve my goals would be to simply replace upper and lower control arms and the brakes. Better handling braking less weight.
I went with QA1. Not light years better than stock, but my K-frame was bent, and I wanted the geometry correction of the tubular arms. I'm happy with the purchase.
