To stroke or not to stroke... That is the question.
Sniper:
CFM 800
Emission Code 3
Flange Style Dual Bolt Pattern
Fuel Pressure 58.5 PSI
Height 3.28"
Injector Size 100 lb/hr @ 58.5 PSI
Max Horsepower Rating 650 Naturally Aspirated
Product Type Sniper 4BBL TBI Kits
Throttle Bore 1.6875"
Terminator:
CFM 950
Emission Code 3
Flange Style 4150
Fuel Pressure 43 PSI
Height 3"
Injector Size 80 lb/hr @ 43 PSI
Max Horsepower Rating ?
Product Type Universal Terminator TBI Kits
Throttle Bore 1.750"
Correct, but nothing that can be easily listed in a spreadsheet. For the most part they work exactly the same. The injectors are the same (it's the PSI setting that makes them look different), bore size means very little at this level of HP. The biggest difference is how they look and the fact that the Sniper has everything built into the TBI unit, even the ECU. The Terminator is a double pumper look and the Sniper is .. well ... a sniper. Tuning is the same.
Yeah, I really like the packaging of the Sniper. Just so nice, clean and simple :)
