tranny i.d.
the trans is for a 68. I posted the same info in your other post for the same question.
The small stamped number on the flat pad under the larger stamped number is what is needed and I cannot make it out.
You seem to have gotten the year model at least.
The numbers on the pad are as follows:
top row: 8A24838 D
bottom row: PP8332428 025
Does it have a 18 or 23 spline input shaft? 18 spline 440 4bbl, 440+6 or Hemi. 23 spline 383, 340. The bell housing will also determine if it came from a BB or SB. Where is the shifter mounting point located, at the rear or front of the tailshaft? Does it have a long or short tailshaft? Long=B-Body, Short=A-Body.
440 4 BBL should also have the 18 spline.
The 2428 in the PP number is the date code and I think the 025 is the 25th one built that day. 2428 = Mar 21 1968 according to my info.
