Tremec vs Keisler
dickdale
6:45 AM
Europe
I'm looking for a 5 speed. Is there any difference between them?
Keisler has used Tremec for years. Now they are partnered with someone else. Both Keisler and Passon have over promised and under delivered their new 5 speeds. The early TKO Keisler/Tremec in my Coronet is fine for low rpm cruising but has a 2-3 high rpm shift problem. Whatever you buy, don't buy an early one. Wait for others to pioneer.
There is Richmond Gear 5 speed, street, road race & Over Drive 5 speeds also...
there's also Doug Nash 4+1, some guy over on Racing Junks sells stuff for them, he claims almost any drag racing ratios available...
Brewers Performance & Passon Performance also, some 5 speed O/D aren't available yet too, 4 speed O/D's are thou...
I watched a show with the guy from Keisler showing what they do, from what I saw they just take a Temec and modify it to be a bolt in application. I believe they mostly alter the shifter location. So I guess a Keisler is just a modified Tremec. Good luck
