Do not discount the starter motor.
I am going to relate a story from a recent problem with a Ferd car that we have. The engine is a 250cui straight 6, and EFI...blah blah. Anyway...I had been getting a load of fault codes up for a while now. One day not long ago, I drove for about 40 miles, pulled up at my electrical supply shop, and tried to restart after about 10 minutes. The engine would not even turn over. Immediately I suspected the battery, and sure enough - it was hot to the touch on both posts - Pos &Neg. So, we tried jump starting with another running car...no luck. All the engine would do was 'grunt' and not even look like turning over.
***Worth noting that this is quite normal - if the non-running car battery is dead, most likely another running car & battery will not help much.
I went over to the local SuperCreep Auto store and bought a new battery - big spendy (mucho denaro) ....installed, and still no go.
Called a local Tow Truck to drag the POS home for inspection. He pulls up, drops his ramps, and e are ready to winch the car on board the flat deck. Just for S&G the Towie says "Give me the keys" ....he jumps in and tried 3 times to start the car - third time it roared into life.
Luckily for me, I know the guy, so he said it was my lucky day, and no charge for stopping by. He wouldn't even take some beer money when offered. I get home and start trying to figure this out. The very next day, when the car was cold, it started fine...a little sluggish winding over....but it started.
I went out to see my buddy Cliff, and we discussed the situation over coffee.....decided the best course of action was to check the codes. The guy in the shop next door had the comprehensive Scanner tool...so he found dozens of codes. The crux was that it looked like the voltage was dipping just a little too much - and since the Ferd model we have is very sensitive to voltage variations, the on-board computer was throwing a hissy-fit every time we started it.
The decision was made to replace the starter motor - a bit radical at this stage, but other ideas didn't seem to stack up as much. I had remembered that the car had wound over a bit sluggish for some time. The original battery was put on a super duper battery charger, and showed up as being as good as the day it was installed....nothing wrong with it. After we installed the new starter motor, the car absolutely roared into life, with much more vigour than I could remember ...ever. At this point we decided to examine the old starter (it had been only in the car for about 3 years) - we found a massive build-up of carbon dust, and the commutator looked a bit heated. It would appear that the excessive carbon build-up was causing enough of an electrical short to pull down the battery voltage during cranking. This was what appeared to have been triggering the codes.
Since then, the codes have been cleared, touchwood none have returned, and the car can be cranked & started after 3 weeks of sitting idle. Before this, if it was left for anything more than one week, the starter motor was very sluggish.
So, please do not rule out your starter motor Greg......you never know.
Here's a picture of the car....photo courtesy of the Speed Infringement Division of the NZ Police.
