Will 66 and 67 chargers steering column fit a 67 dodge
I know '66 columns are different from '67's. '67 was the first year of the collapsible column. Sorry, I can't tell you if they interchange.
I just looked at a 66 charger and the column is a totally different animal than my 67.
However, I just restored a 69 floor shift manual steering column to put into my 67, and they are close enough to each other that no one will ever know. About the only differences I saw were how the bearings were retained in the columns, and the 67 bracket that bolts to the column under the dash is shaped just a little different. I just unbolted the 67 bracket and bolted it to the 69 column. That being the case, you should be able to use a 67-69 column.
they will not interchange, completely different column.
Bryan
