Wiper Motor Wiring
Beavis
8:43 AM
Berkshires
Question: what is the wiring config on my 69 A12 wiper motor ? i have 4 wires Blue, Red, Brown & Green.
i know the blue get constant when the key is on but not sure what the other 3 are configured to make it work properly. the switch just has 2 positions besides off
its a 2 speed wiper motor (2983116) with 4 wires. the manual doesnt tell you what wires deliver 12v to the motor for each speed. i dont think its 1 wire per speed with 4 wires going to the motor
the color code in the diagram should show witch wire goes where. in the manual for testing should help show witch wire dose what.
The manual will show which wire goes into which socket in the 4 pin connector. Also, on that motor the speed is controlled by the ballast resistor on the motor. It doesn't matter if you get those two crossed.
Test Procedure Page 1:
Test Procedure Page 2:
Engine Wiring Diagram for Wiper Motor:
Insturment Panel Wiring for Coronet:
Download the manual referenced above (FREE), and see it better...
