SOLD 1970 GTX 440+6, Hemi 4 spd, 4.10 Dana, N96 (Project car)
72ls5fla
9:56 PM
Tallahassee, FL
Feedback: 19 / 0 / 0
Hello -
I am selling this vehicle -1970 GTX 440+6, Hemi 4 spd, 4.10 Dana, N96 (Project car)
Car is a real legit car. built in OCT 69. Original mileage is 41,850 miles.
Has original fender tag, dash VIN plate, and all stamped numbers on the body.
The Dana, drive shaft and leaf springs original, the trans is original (with VIN stamp) and the engine is a Date and Casting number correct replacement with a perfect casting date, upper pad HP2,F440,922 build date.
Has the original K frame with all the original suspension parts. Came with disc brakes and power steering. It is all there (wide mouth calipers, rotors , 980/81 torsion bars , trans cross member etc..)
The front floor section, cowl cover, lower core support, trunck floor, drops, both rear quarters, panel below rear window and tail light panel all professionally and correctly installed.
quarter panels properly gapped to doors and deck lid to the quarters and lower window panel and quarter extensions.
AMD sheet metal or OEM when able.
90% of the metalwork all finished.
Included are two NOS fenders (striped and epoxied) plus the original PASS side.
ALL SHEET METAL - is with the car, can be assembled and bodywork/paint done.
Cost of work was right about 14K
Engine short block rebuilt way before I got the car two years ago. See pictures.
Engine does not come with sixpack setup, dual point distributor, starter, fan clutch, exhaust manifolds or alternator.
Does have -
1. 906 heads (need valve job)
2. original oil pan and windage tray
3. original water pump housing with water pump.
4. timing chain cover
5. all pulleys
6. several engine accessory brackets.
7. rocker arm assemblies
8. gear drive-shaft for oil pump
9. motor mount brackets
10 original Z-bar
11. NOS lifters
In addition it does come with:
1. back seat upper/lower frames
2. original shroud
3. original wiper motor
4. all Front door window guts and glass.
5. all 1/4 window guts and glass.
6. Leaf spring rebuild kit
7. ralley dash frame and very nice black OEM dash pad.
8. drip rail stainless
9. window weatherstrip stainless trim
10. original front grill and trim
11. original rear and front bumpers (need chrome) + brackets
12. original front lower turn signal (in bumper) assemblies
13. original rear backup lamp assemblies
14. all N96/Air grabber parts that were attached and part of the hood assembly.
15. original very nice hood hinges.
16. front buckets and tracks.
17. original brake booster (no master).
18. Box of dash parts (cluster, some switches, some chimed panels, original ash tray, original
air grabber switch, reverse light, steering column attachment bracket.)
19. stainless for holding door panels and rear 1/4 window panels
20. upper front door panel woodgrain trim parts (in need for full restoration)
21. upper rear quarter rear metal trim panels.
22. original seat belts but set is missing some (back seats) and needs restoration.
23. NOS side and rear GTX emblems
24. NOS front marker lamp assemblies
25. some stainless trim for GTX rear panel
26. original rear PLYMOUTH letters
27. Re chromed original exhaust tips (super nice).
28. original rear tail light assemblies with inner plastic covers.
29. Original 4spd console, pot metal chrome parts, door side trim (missing bulge
on DVR side)
30. Black Headliner
31. OEM kick panels (need dye)
32. Pair OEM A pillar (need dye)
33. ALL dash plastic - needs dye
34. Plastic trim that that goes around back window (in black) - great shape
35. OEM over head light fixture + cover
36. all upper trim for headliner, + bows and bow hardware
37. New ECS exhaust system (SS H-pipe, logo/dated mufflers, CS tail pipes, muffler hangers)
here are body pics of the car.
https://www.icloud.com/sharedalbum/#B1455Z2WMJIWpox
pics of drive train
https://www.icloud.com/sharedalbum/#B145NI45MJGb9d2
Pics of parts
https://www.icloud.com/sharedalbum/#B145CmvASGmath5
$30K or sane reasonable offer .....
located in Tallahassee FL
Local pickup only please.
Bill
Additional Info for ad - (edit button is gone)
Under included in sale:
38. the Rear upper and lower seat frames are included.
To Be Excluded (defective)
Car price adjusted down to $29,500.00
