I can tomorrow, I have an AC car originally, but none of the components are left, were removed before we ever bought it.Can you take some better photos. Maybe in better light? Or a flash.
What are the return springs connected to?
Do you have a/c?
Thanks a million! I'll get better pictures when I get home from work this evening, and I'll check on that bracket, as you're correct, no tension on the spring so that's why I had to use the old spring! I'll try to fix the linkage per your comments above. I can't thank you enough for your comments, you've been a HUGE help!
How’s this? I put the washer in the other side, and I turned the bracket around so there’s tension on the front spring and then I reversed the other spring.
What about my kickdown “turnbuckle?”Now, there is too much tension.
I think the return spring bracket is supposed to be in the end intake bolt.
Thank you, I’m testing it now!Fine tuning.
Try adjusting it so the kickdown is fully back slightly before you are at WOT.
It shouldn't affect you opening up the throttle fully - there's enough play in the linkages to allow this.
My factory to Eddie is a 1/4" 24 tpi. I got a bolt from the hardware store, sawed off the top and used it to extend the linkage. Works perfectly. Good luck.I have a new AVS2 on the way as well as the throttle adapter for Chrysler cars (Edelbrock part #1481), as my linkage on my Holley that I'm replacing isn't correct. I also ordered the stud for that linkage setup as well (Part # 8007). The only thing left to order is the rod extender, but there are two options:
1. 1/4" rod extender (part # 8003)
2. 5/16" rod extender (part # 8004)
My car is a 1969 Dodge Charger with a stock build (but bored 0.60 over) and an Edelbrock intake that has DP4B stamped on the top. I have the factory 727 automatic throttle cable and kickdown turnbuckle style lever, but it's rigged up with nuts and bolts to the Holley I'm replacing rather than proper hardware.
Does anyone know which one I need? Does it depend on the size of the hole on the carburetor linkage? Does it depend on the size of the shoulder stud I just purchased (part #8007)? If so, what have you guys used? Thanks in advance for the help! Trying to order it and get it shipped and here before the weekend!
