Ford 9" as a replacement for 8 3/4
PeteyDaMan
1:37 AM
Chester, NY
Hey all,
I'm looking to upgrade my 8 3/4 for something stronger. I'm afraid I'm going to destroy my 8 3/4 while dumping the clutch on the dragstrip.
I know Strange has a great S60 setup but I like the option of having the removable gear sets.
Speedway Motors has a Fabricated Ford 9" setup for a decent price and it looks pretty beefy.
https://www.speedwaymotors.com/Spee...rend-Axle-Housing-Kit-58-In-Width,297526.html
Anyone using one of these and is it strong enough for a 4 speed and the track?
^^^^ at least a 35 spline, if you're already spending money
Sure you need to do it?
What are:
Engine, Trans, Gear, Tire Size and suspension setup?
What are:
I just copied this out of a different thread so it has more info than you asked for.
71 Charger with a mostly stock suspension.
Super Stock leaf springs
1.03 torsion bars
Bilstein's on all 4 corners
QA1 tubular upper control arms
Borgeson steering box
8 3/4 with 489 case with Richmond Gear 3.55 sure grip
MT Drag radials 295/55-15
Engine:
512 Eagle Stroker kit
10.4:1 compression on 93 octane
Comp Cams hydraulic roller cam laid back 4 degrees 286/294 .544/.541
Eddy RPM heads
Eddy RPM intake
AED 950 cfm carb
TTI 1 7/8
MSD 6AL and billet dizzy
Tranny:
18 spline A833 built by Brewers
McLeod twin disc clutch
1.03 torsion bars
Engine:
Eddy RPM heads
Eddy RPM intake
AED 950 cfm carb
TTI 1 7/8
Tranny:
Dumping the clutch on 650 horse? I think I'd go with a Modular 9". Quick Performance is another place that specializes in those. Quick Performance: Differential Parts & Components
Think really hard about how often you'll change gear sets !!!
Doctor Diff can set you up with whatever you need. I had him supply me with a complete Strange 9 inch for my last project. Pulled the Dana out and sold it and installed the 9 inch.
