- 11:37 AM
- Dec 3, 2020
- western Maryland
So, not a B body but it is a Mopar - my 06 Wrangler. D35 rear was roaring, so I pulled it open. Ring and pinion teeth look pristine so I'm going for bearings. Outer axle bearings (they're easy and cheap), inner pinion and outer pinion (common fail point). Carrier bearings look and feel great (my opinion and that of a local jeep guy I ordered parts from; had the parts in a bucket for fresh eyes before ordering), so I'm not messing with them this time around.
My concern is the pinion bearings, and setting proper depth. It's a crush sleeve setup, with shims for the carrier bearings.
I have calipers to measure shims. I have a slide hammer, I have stuff to drive the bearing cones out of the case and can make something to tap the new ones in (a day in the freezer will hopefully help too). Got torque wrenches.
I don't have a dial indicator, and I'm not sure how to set the pinion depth. Is it a matter of just torquing the pinion nut to spec? Can I check the teeth with gear grease to read the pattern, and that will tell me? Also I've read a couple writeups that say to use a new pinion nut as they're single-use....
Thoughts?
Am I screwed? Or can I make this work?
I have the axles out. Carrier out. Caps and cones and shims labeled and zip tied into position. Getting new spider gears because one tooth was broken (the ONLY tooth in the whole rear that had any damage on it...weird). Pinion gear and bearings are out but cones and seal are still in. Outer axle bearings and seals are out.
New parts on order are outer axle bearings and seals. Inner and outer pinion bearings. Crush sleeve. Pinion seal. Spider gears. And a carrier shim kit, just in case.
I've built engines. Transmissions. Electrical. Just about everything on a car...and motorcycles from the ground up. I'm "mechanically inclined"...but this is my first diff.
And, I'm doing it under the vehicle, with no lift.
At least the garage is heated.
Thoughts?
