Master Cylinder push rod question
dan juhasz
5:38 AM
Whiting NJ
So the 69 A12 that I purchased was originally drum/drum. The previous owner installed a common front disc brake kit but continued to use the drum/drum master. I ordered a master from online tube that was listed as manual or power brake application. My concern is the piston does not have the machined groove to lock in the push rod. I called pirate Jack and asked about their master cylinder and he said it would also not have that groove. Is there a factory appearing master cylinder for manual disc brakes that has a groove to lock in the rod?
I bought one from NAPA for a 1973 Dart with manual disc brake. It had the groove and pedal feel is just right.
But this was 30 years ago. Don't know what they sell for that now.
Yep. Put one on this . Worked like a charm.
That display picture for the master doesn't even show the bolt holes to hold the boot over the pushrod. Do you remember doing your install? Did it have the provision for the retainer and push rod boot? Did your push rod snap into place and stay locked in?
No boot or provision for the boot on the back side. But yes the internal piston has the groove for the retainer to snap into
By application the one I linked above is for Power disc brakes,
This one is listed for manual disc brakes. BUT it has the larger piston / bore size. Which is not ideal for manual disc brake converted car. At least so I am told.
I went with the smaller bore size on the car . And had no complaints
But neither one have the provision for the boot on the back side
This is in my Dart. Has the groove for locking the pushrod . You can use a piece of vacuum hose to lock the pushrod in if your old one is bad.
