Road Grabber
- 10:05 PM
- Apr 14, 2020
- Sarasota Florida/NY State
Thanks! No, I need to change the antifreeze for sure! It can overheat, but it runs at 160 degrees unless I'm in traffic for too long, as I have the wrong radiator (from a 1070 C Body that was installed before we bought the car in 1996). I have a temp gauge hooked up (not the factory one) under the dash, and it hasn't overheated excpet one time when I was caught in traffic. It got up to about 220 for about 5 minutes. Other than that, it stays at 160 degrees.
Also, the carb was rebuilt and then tuned by a local carb expert. We also checked the float levels and they are spot on. It just trickles out. I definitely have brake problems. Dr. Diff diagnosed my brake issues through pics I sent him and my car has the wrong brake booster, and non-Charger parts on it unfortunately. I have power front discs and rear drums, but it's a cobbled together mess.
Thanks again for the help!
1. Did you plug the vacuum line going to the brake booster to rule it out? You said it was a mess.
2. When was the last time this engine ran without the issues? If it ran previously without this issue you can at least say it's PROBABLY not a mechanical issue.
3. You mentioned having a stock cam installed. You may need to verify if not now but later if nothing else works if the cam has skipped a tooth or was not installed properly.
4. Does your rotor under the cap point to the correct position when at TDC? The engine could still run but not necessarily well if the distributor gear is in the correct position. If you remove the distributor you can look down the engine. At TDC the distributor gear slot the distributor fits into should be pointing straight forward. Even if the engine runs that needs to be in its' correct position if you want to do things right. Even engine builders make mistakes or don't know Mopars well enough to install them right because many of them do mostly Chevy engines.
5. If you haven't already you should verify there is not a lean condition like suggested before. Start the engine and while running and begin cover the top of the carb (or close the choke a bit) and note what is the reaction of the motor. Does it bog/want to stall? - Meaning too rich to run. OR Does it pick up speed - meaning the engine is starving for fuel and is lean.
6. Pull the plugs and look at them. Spark plugs tell you everything going on inside the engine. Take pictures and post if possible. Keep your spark plugs in order the way they come out.
Are they black?-too rich.
Tan? - good fuel ration
White - Too lean running hot
OR do they look brand new - that cylinder is not firing
What does the exhaust pipe look like? Black? covered with soot? Tan?
Can you feel popping and misfires at the exhaust? Which bank/side? One or both?
You have replaced a lot of parts new but you need to rule out systems or parts of systems to narrow this down. Pump, carb, new fuel, lines etc.
BUT you have said the wiring harness(es) are a mess. It is steering more and more towards an electrical issue if that's the case after ruling other things out.
***7. If you want to completely rule out the engine wiring harnesses and eliminate other issues,
Get a point distributor. (You should be able to get a used one or buy one. You bought everything under to sun anyway and it's good to have around)
- make sure it is a correct one for 383
- install NEW points, condenser, cap and rotor
- remove/disconnect the engine wire harness for a test
- Make sure you are aware of the rotor position and don't install the point distributor 180 degrees out - you verified the cam gear slot right pointing forward at TDC?
- hook up the point distributor to the negative side of the coil
- make a jumper wire to connect from the positive side of the battery to the positive side of the coil. Make the connection at the battery easy to pull off but a good connection
- start the engine
- IF it runs well you have ELECTRICAL issues
- Don't let it run tool long with the jumper. To make it stall just pull the wire from the positive battery as it will harm the coil over time without a ballast resistor.
***This will eliminate ALL of the worn out/possibly melted somewhere or fused wiring somewhere under the dash, or in the wiring harness. It will also eliminate the possible wiring issue you may have with your electronic ignition components.
If the engine runs well with the point ignition system at least now you know it is NOT fuel, NOT a vacuum leak, NOT a mechanical issue BUT IS an electrical issue that now can be troubleshooted. It could also suggest a possible distributor problem.
This will allow you to concentrate on just one area instead of chasing everything around from all directions.
If you STILL have issues you can still use the point distributor if you like if you adapt the wiring. It's pretty easy to convert back temporarily or leave it....
MY TWO CENTS _ Have at it and report back!
