- 9:17 AM
- Mar 10, 2010
- Hanover, Pennslyvania
I thought my 62 was close but it does seem a bit off. This is an aftermarket advertised as 62 Savoy only. Was that Pattern in a base Dart? Go, Joe, Go! Get er done.
Your timing is impeccable! I just ordered my trunk mat yesterday after extensive researching.
My conclusion is nobody makes the correct pattern for the right application. Maybe for one exception that I found and that's the "Hash print". But you can't get it in a molded mat.
Like it has been discussed many times over, REM and ACC are the only two manufacturers of these mats. Each offer different patterns, some close to one another but only similar to the factory patterns and not exactly. (I'm researching 1962 only.)
I've found two original mats in the 1962 Dodge. A light Plaid and a Hash Print.
Original Plaid mat 1962 Dodge Dart.
Original Hash Print 1962 Dodge Dart. Both pictures are from the same car. Lighting on the second picture looks blue but it's grayish. Picture of this pattern from a car at Chryslers at Carlisle that was original.
Picture from Chryslers at Carlisle Dodge.
Online sample picture from REM
When I bought my '62 someone had removed the trunk mat so I have no idea what it looked like. That's one of the reasons I tried to find out what was used. I have discovered these two patterns from the Hamtramck plant. I've seen both of these patterns used in the Plymouth B bodies also.
So my next question was will a mat advertised for a Plymouth be the same as a Dodge? You would think they are but they even advertise Belvedere separate from a Fury/Sport Fury. Why would they be different? I thought maybe it had to do with the patterns but they offer the same patterns for both. (The convertible vehicles take a different mat altogether.)
Most of REM mats are flat not molded. ACC mats are mostly molded but are thinner vinyl. Not the "table cloth" thin vinyl which is also out there. Talking with Joe Shusy, he was trying to get Rem to give ACC the Hash Print material so they could offer that in a molded mat. They won't do it.
So I happened to stumble across a Plaid Print, rubber mat from REM that is supposed to be molded. The only catch is it's for a '62 Plymouth Fury. I'll let everyone know how it fits the Dodge when I receive it. It's still in transit from Classic Industries in California. (They had the best price and it was in stock)
And if fits and if it is molded, there could be a good chance they can mold other patterns and offer them for the Dodge.
