Don67Satellite
- 11:15 AM
- Dec 16, 2021
- Abbotsford, British Columbia, Canada
Mulling over some of my winter project ideas....
For those here that are using Progression Ignition, I just had a curious question, in the wiring diagram, it shows, to my eyes, a keyed power source hooked to the positive side of the coil. In the instructions it states "The distributor will operate on a negative ground, 12 volt electrical system. It must receive full battery voltage during all operating conditions.
VERY IMPORTANT!!!"
Also the normal warning about the ballast resistor.
I am just asking where others ran this single power wire to, that will provide full battery voltage in, I assume, crank, start and run...
Thanks in advance.
VERY IMPORTANT!!!"
Thanks in advance.
