69'Net
I have a 770 avenger on a 440/auto. The idle mixture screws were set on a Dyno with an air/fuel gauge. I had to send the carb back to Holley to fix a crack in the casing. Now I'm having idle issues. I tried to adjust the screws with a vac gauge but the vacuum is unresponsive when I turn them out. They only change I see from 15in is when I start screwing them in. Should I buy an air/fuel ratio gauge or am I missing something. I did this with the car in drive and the screws 2 1/2 turns out to start btw.
