threewood
So I have been looking at my combo and thinking about getting a new cam with a bit more duration but was wondering if that is my bottleneck for more power. Not too woried about street manners and would like something a bit more lumpy at idle. I do intend to race a bit at the track in Roswell, which is 3573 elevation.
Here is what I currently have...
440 block, .040" over, stock stroke
Forged crank
KB 237 pistons zero deck
FelPro head gaskets .039" compressed
Stealth Heads, CNC ported (Intake 311cfm @.550 lift / exhaust 210cfm @ .550" lift)
Hughes 1.5 Rocker arms
Holley Sniper EFI 550 (650 max HP)
Holley Street Dominator single plane intake
1 7/8" long tube headers into 2.5" exhaust
Pertronix Ignitor III
Cam - Hughes STL3842BS solid lifter, 105* centerline, Duration at .050" 238* / 242*, Lift .558" I / .564" E
PTC 9.5" torque converter
3.55 rear end ratio on 275/65 R15 tires
Air in, air out right? I like the cam but the engine seems to top out a little over 5700 rpms, which is where the cam power band ends. I was thinking a similar cam with more duration to bump the power up into the 5900 - 6000 rpm range. Car has plenty of power down low as it sits. But am I hitting a road block with the intake or the headers or even the heads?
Best 1/4 and E.T at 3573 elevation was a 13.15 @ 106.81
Looking at the Hughes STL4650BS, centerline 104*, duration at .050" 246* / 250*, Lift .576 I / .588" E. I would be able to keep my springs as the specs are identical as to pressure. And I want to stay with solid lifter. I'm not interested in going roller.
Thanks!
Forged crank
Thanks!
