DynamicXX
- 8:10 AM
- Dec 23, 2023
- Corbyville, Ontario, CA
I'll start with what the issue is and what I have done. Car wont start. 1969 Super-Bee, 383, AVS2-Edelbrock, 4 Speed. Car ran fine last year after I purchased it, car was a runner when purchased, (September 2023), put about 200 miles on it, winterized, (fuel stabilizer added, changed oil, Diff, Trans fluid, coolant flush, kept in heated garage, I'm in Ontario, Canada). This spring, wouldn't start; good spark from what I can see-strong blue kernel; running 93 or 94 octane but both brands/octane levels have 10% ethanol, which I'm not sure really matter's at this point; battery tested a little low, so bought new battery, date stamp on the old one was 2018, checked for vacuum leaks, all new hoses, etc. Definitely flooding. Took carb to a mechanic that builds engines for stock car's, knows carbureted engines, etc., he put in a rebuild kit, said needle (1) was sticking, and the carb was dirty and actually missing part's??? Get carb back, installed on the car, car starts up, runs a little rough for first few seconds, like it is too rich, ran a few times, now it's back to not starting. Slight smell of gas, I can see the gas being shot into the bowl's. The mechanic is deep into other projects and running a business, so wont be able to look at it for a few weeks unfortunately...I am mechanically adept, (built and raced motorcycles back in the day), and would like to fix this myself, but am smart enough to know if/when I need help and will take to another mechanic if needed.
