69440yellow
I am experiencing some issues with my front end. There is a lot of play when wiggling the tire so going to replace wheel bearings. But my question is about the calipers. I have never seen bridge bolts like this. Is this normal.
I think you have the wrong set of slider pins, then. I have this same setup on the front of my 1964 Polara, and it works great. I think there are two different lengths of pins, depending on which year of caliper being used.I tried to tighten them up but they are already bottomed out. I agree it seems that they should at least have a large portion of the shoulder in the caliper.
I would hafta agree with Dave6T4 with his reply.I think you have the wrong set of slider pins, then. I have this same setup on the front of my 1964 Polara, and it works great. I think there are two different lengths of pins, depending on which year of caliper being used.
Ma Mopar did away with those things in later years on the pin calipers as it was determined that they really didn't do much good anyway.What no one missed the anti-rattle clips that also hold the rubber bushings in place
The clips don't hold the bushings.. Thousands upon thousands of those style brakes on the road, lots don't have the clips & the bushings stay where they belong as long as they were properly installed in the first place... The clips were out of production for years, they've recently become available again but the price is insane, last time I bought one they were about a buck apiece, now it's something like $100 for a set of four..What no one missed the anti-rattle clips that also hold the rubber bushings in place
In 1970 the positioner clips were a one year design and that if your a "restorer" for a disc brake system and want to be 100% original, that's why one pays 100 bucks for those things, in the reproduction world.The clips don't hold the bushings.. Thousands upon thousands of those style brakes on the road, lots don't have the clips & the bushings stay where they belong as long as they were properly installed in the first place... The clips were out of production for years, they've recently become available again but the price is insane, last time I bought one they were about a buck apiece, now it's something like $100 for a set of four..
Yep and that would also cause improper bleeding of the brakes to not be done properly. Switch the calipers so the bleeder Zerk fitting is at the bottom so as you will get better bleeding thanks to gravity. DAMHIK...cr8crshr/BillLooks like the bleeder screw is in the up position ?
Thank you for the replys,, I wonder where I can go in the northern area of Tampa to get help with parts to fix my problem.You should always mount calipers so bleeder is at the top to get as much air as possible out of system. Check your FSM.
Where in the world did you ever come up with that?Yep and that would also cause proper bleeding of the brakes to not be done properly. Switch the calipers so the bleeder Zerk fitting is at the bottom so as you will get better bleeding thanks to gravity. DAMHIK...cr8crshr/Bill
