Not Enough Whiskey !!!
Bryan Refino
7:59 AM
Rhode island
Hello , back again for a little more guidance , I tried looking for a similar problem in previous threads and cant find what i am looking for so I will try here , I have a 1969 Plymouth sport satellite 318 auto on the floor factory ac car , the problem I am having is ( previous owner "fixed some wires himself) i am currently tracing all the wires under the dash because all my lights work fine headlights marker turn signal , brake lights etc. EXCEPT when I turn on the headlights the FRONT ONLY turn signals stop working , the rear still work but the front cut out every time any suggestions ?
Sounds like it may be a bad ground.
The turn signal filament may be grounding through the headlight bulbs.
I would suspect a bad ground as well.
