Radiator shroud question
Chi Town Runner
6:08 AM
Tennessee
I have the two piece metal shroud that I used on my '68 Road Runner radiator 2898 043 with the 22" radiator
I want to give the shroud to a friend for his 22" radiator on his 440 Coronet R/T
My concern is:
1 - did the Coronet R/T use the same size fan and:
2 - due to the difference in engines will the shroud opening be positioned correctly
Thanks to all
If the 69 radiator is the correct one (2949053) the 68 shroud will not mount on it. In 69 the shroud changed to a plastic one and uses different mounting brackets.
Sorry. I failed to mention his R/T is a '68, same year as my RR
I should have put that in.
Thanks anyway, I already gave it to him, we'll see.
Frank
As long as its the correct for 68 Radiator it will work, PROVIDED his has the side brackets on it Which bolt on for the metal shroud
1 - did the Coronet R/T use the same size fan and: YES
2 - due to the difference in engines will the shroud opening be positioned correctly YES
Thank you.
I've been on this site since '08 and I'm still amazed at the amount of help and knowledge offered here.
