I recently picked up a 68 Charger RT and know very little about the car. I noticed the leaf springs are almost flat and straight when I was under the car the other day. The springs appear to be exactly the same on both sides with five complete leafs (no halfs). The rear shackles are leaning very far back leaving only about a half inch from the rear eye to the frame rail. I plan on replacing all the bushings, but wanted everyone's opinion regarding the flatness of the springs and the angle of the shackles. I read other posts and it would seem many people say the best way to tell if the leaf springs need replaced is by how the car drives and not necessarily from looking at the arch of the spring. Some folks on here also say there should be a positive arch in the spring while others say they should be flat when on the car.
Shouldn't RT cars have 5+half leafs on the left side and 5+two half leafs on the right side?
Do these springs appear too flat or not bad enough to worry about for now? (just appearance for now: I will drive it once I get the transmission replaced)
