About this Mopar:
1965 Satellite Hemi race car, I own it for 39/yrs and spent over $50,000 on it and I have all the bills ! It's time to let it go.ROLL CAGE CERTIFIED FOR 7.50 . The motor is a 498 ci with the best parts money can buy ! 2/1050 Holleys carb ,Stage 5 Engineering heads & rocker arms, porting work done by them flow numbers are in 550 @ 850 lift I have the paper work on them, and they are the best ! Piston's are JE 4.310 comp is 15.37-1 , Rods are Fowler Billet Con-Rod good for over 400 runs on a super stock Hemi @8500rpm.
Jesel Timing Belt Drive Systems, Cam is COMP Cams lift is about 900. Crankshaft is a Moldex Crankshaft 4.250 . 4/wheel disc brake , Rack and pinion steering , Dana 60 Strange Engineering Lightweight Pro Race Spool & Axles , Richmond Gear Pro Ring and Pinion 513 ,Trans hads lot's of good parts too I believe I have the only unbreakable sprag in the world it has 64/element's or you mite call them roller's , check for your self to see if there is a sprag like this for the 727 for sale! Much more to say but you can call Mitch ----------347-204-5234 for more info
NO TEXT JUST CALL MITCH . I'M OPEN TO OFFERS NOT SURE WHAT I WANT YET , SO JUST CALL AND TELL ME A $ NUMBER FOR ME TO THINK ABOUT.
key words- Mopar 990 Belvedere, Barracuda, Dart, Road runner, B/body, A/body, GTX, GTS, Duster, 383,400, 413, 426, 440,
http://newyork.craigslist.org/brk/cto/4004952901.html pics are here too . 35,000 wil buy it.
