1966 Dodge Charger
383 Dodge Charger with a bit of work to be done.
About this Mopar:
Originally white with red interior? Later painted blue then red.
Car has had a 383 installed over the original 361
Everything from the engine bay to the dash has been rewired and or painted over. Bringing back the factory wiring is top priority once tuned up abd brakes fixed.
The 727 has been rebuild ( I am told ).
8 3/4 rear but I've not yet checked the ratio.
Lots of work to be done! But we're exceited to get going
Latest updates
Here are the switches I used for my motor limits
The dash and radio light up, car has been started up. No real issues after completing the rewire.
Radio doesn't work however nor does the tach, but need to investigate
The headlight motors did workout, fully functional, made new switches, had to modify the bracket to fit a slightly smaller switch - couldnt source originals.
Been working on this car since March. Floors are Done, original Dash and radio are in, car has been rewired back to factory from that garbage that was in it. In the reassembly phase now
blue69runner
blue69runner
very nice. It feels good to see a car coming together.:thumbsup:
Comments
Nice find Vinny! The '66 Chargers are beautiful cars. This one is a true veteran that just hasn't had enough TLC lately. Hope you're able to give some much deserved glory days back to her. Best of luck to you!
Thank you guys!
Definatly needing tlc but it will get it here
This charger has a long road ahead but ill have to post some updates as it goes
Nice car. Too bad they removed one of the very best attributes of the 66-67 Charger: the dash with electroluminesence lighting
Yes i know, and rewired the car to boot.. but i have a decent dash and harnesses. Trying to learn what i can about it. We'll get it back
White has a lot going for it if that's what the intent it.
Hats off to you for tackling the wiring and cluster on one of these cars.
Thanks alot, white would be my preferred color - Either white or black but a nice white would look great. The wiring is defiantly a pain
Item information
Category
FBBO Member Photo Garage
Added by
Seivad
Views
1,774
Watchers
4
Comments
8
Updates
3
Last update
Rating
5.00 star(s) 3 ratings
Share this item
