1967 Coronet 500 convertible
Follow my journey of a budget build on a pedestrian, but very cool 67 Coronet.
About this Mopar:
Year
1967
Make
Dodge
Model
Coronet 500
I picked this up on Ebay in Sept 2017. When I drug it home, it was running off of a lawn mower tank in the engine compartment, had no brakes, not even an ebrake. The exhaust was Swiss cheese. Most of the lights didn't work. None of the floor shift mechanism was installed. Even the seats weren't bolted in.
As you can imagine, the journey into the trailer and my driveway were white knuckle rides.
The good part was that it was a Georgia car since the early 70's with solid frame rails. The previous owner installed a new one piece floor pan. All of the convertible parts are there and in good working condition. The 318 has 86,000 miles, the 727 is out of a 70 340 and is tight, and the 2.94 pegleg rear is quiet.
I've recently received a copy of the original IBM punchcard for this car and discovered that it was sold new at Coleman-Young Motors in Willoughby OH, just north of Cleveland. I'd really appreciate any info or pictures of the dealership.
In the past, I've:
Replaced the entire brake system from the master cylinder to the wheel cylinders, including all the steel lines. (Autozone, Inline Tube)
Replaced the fuel system from tank to carb using 3/8" SS tubing. (Inline Tube, Ebay, steelerubber.com)
Installed the seats, belts, and floor shift. (Ebay, swap meet)
Rebuilt the entire front suspension including bushings and torsion bars. (Dr.Diff via Ebay, Mancini Racing)
Added 14x6 road wheels with Hancook tires. (Craigslist, Amazon, swap meet)
Installed new full exhaust including Y pipe. (waldronexhaust.com)
Engine tune up, belts, rocker cover gaskets. (Autozone, Ebay)
Repaired all lighting and gages. (Autozone)
Replaced the timing chain, front core plugs, and all the hoses, added a timing chain oiler. (Autozone, Ebay, FBBO)
Added LED lights to the dash (superbrightleds.com)
Added front sway bar. (Craigslist, Ebay)
Replaced valve seals and power steering hose. (COMP Cams, Ebay)
Added a passenger side mirror. (Swap meet)
Transmission seal replacement, add a deep pan and partial throttle body kickdown. (Autozone, Ebay)
Add FBO distributor plate. (Ebay)
Replaced U joints and rear trans seal. (Autozone)
New black convertible top and well liner. (Ebay, Dante's, Gillins Custom Interiors Florida, NY)
Triaxial 4x10 speaker and BT amp (Pyle, Amazon)
Rebuild oil pump, desludge oil pan, replace freeze plugs.
Here is my YouTube channel with some tips:
Latest update:
I finally channeled my inner Mike Rowe and did the dirty job of freeze plugs and oil pump rebuild. Antifreeze and oil showers, yum!
Coming up:
Air conditioning (Classic Air, Ebay)
New rear suspension. (ESPO)
Fresh TT1 medium copper metallic paint. (Maaco)
New engine/lighting wiring harness' and alternator. (swap meet)
New copper interior. (Dante's)
Front disk brake conversion. (Ebay)
Add Detroit Trutrac limited slip diff. (Dr.Diff)
Engine rebuild, add stroker kit.
Comments
:elmer:great job, its looking great from what you can see. i love that its a convertible. really looking forward to seeing its progress. have fun! ps, where in upstate do you live? i am originally from Russell MA. and thats where my dad lives and if you ever need someone to do work on your interior/convertible top he is one of the most trusted and skilled in upholstery there is out east. and hes a big mopar guy. you’d have fun just driving out to his 90 acre mountain top cabin to see his 68’ barracuda with a 6.1 hemi. cheers!
Thanks. I'm across the river from West Point. I'll definitely look your Dad up if I ever get up that way.
What a great classic convertible - nice work - can’t wait to see it all finished - congrats !!
Item information
Category
FBBO Member Photo Garage
Added by
JimCoronette
Views
7,615
Comments
12
Last update
Rating
5.00 star(s) 6 ratings
Share this item
