68 Roadrunner 479ci 6bbl resto-rod
Budnicks 68 RR LL1 Surf Turquoise Metallic
About this Mopar:
Still far from done, still need cut & buff
{garage paint job, far from show quality}
BUT;
It's got some color, the engine bay is kind of old & dull
the rest is the OE LL1 Surf Turquoise Metallic
don't mind the date stamps this was 10-2017
I'll add some full photos when I get it out in the sun...
Latest 1st time out in the sun
still no cut & buff 10-29-2017
never mind the date/time stamp this was an hr or so ago
Oct. 29th 1:00pm
STILL Not finished
, but I figured I would share a couple more of photos,
The B_I_T_C_H as she's know 63,000 {now has 67k 10-2013} original miles
She was under a tree for 10 years in Sacramento/Rio Linda area
& had a 3" deep crease down the drivers side when I got it...
Outside is some what stock appearing with a A-12 6bbl lift off pinned hood
& Polished Edelbrock/Halibrand Kidney Slots
15x7 & 15x9 with 245/15/60 BFG Ta's & 295/15/50 BFG Ta's.
68 RR HT 383 auto 0.040" over 4.290" bore,
ARP 12 pt. &/or stainless hardware everywhere, tons of aluminum stuff,
Edelbrock RPM heads, MRE Custom rad, MP Alum water pump housing
& Pro-Comp electric 38gpm pump, MP cast polished valve covers...
Custom Crane Hyd. Roller camshaft & Retrofit lifters, 1.6:1 Super Gold roller rockers...
3" mandrel bent Flowmaster exhaust, Delta 50 Racing series mufflers,
with H-pipe, 3" tailpipes all the way out the rear...
OS Hellwig sway bars 1-3/8" front & 1" rear...
{currently 3.23:1}
Unisteer rack & pinion steering, Edelbrock IE Gas shocks
& SSBC Force 10 disc Brakes...
Original Black Decore interior & Scat-ProCar Elite 1100 series Bucket seats,
Tuff GT wheel, custom Painless 4 switch panel & complete electronics
on a custom relay panel system...
Soon to be a custom gauge panel {see below}...
MP chrome ignition box & adj. vac. adv. MP CEI distributor, new ign. curve,
dual electric BeCool fans 16" 2950cfm puller in a custom alum. shroud
& 13" 2650cfm pusher...
All Aeromotive S/S 175 gpm Elect. fuel pump,
Quick Fuel in the Center 2300 carb & Promaxx performance parts
& adj. jet plates in the outboards, Holley 6bbl set-up,
HP 50cc pump & different springs in the outboard carbs,
New fuel system, new fuel tank, sending unit
& #6 AN feed & #4 AN return lines, Aeromotive bypass style fuel reg. & gauge...
i10317.jpg 68 RR #29 479ci-6bbl #6 AN lines & phenolic spacers.JPG 68 RR #27 479ci-6bbl.JPG 68 RR #30 A-12 6bbl pan & fresh air air-cleaner w-phenolic spacers.JPG
68 RR #36 479ci Fuel reg. fron to engine rad etc..JPG 68 RR #37 Power Steering Pump for Unisteer rack & pinion serpintine belt acc..JPG 68 RR LL1 10-29-2017 #1 DS frt.JPG 68 RR LL1 10-29-2017 #2 DS rear.JPG
68 RR LL1 10-29-2017 #3 PS rear.JPG 68 RR LL1 10-29-2017 #4 PS frt.JPG 68 RR LL1 10-29-2017 #5 frt hood.JPG 68 RR #27 479ci-6bbl.JPG
68 RR #30 A-12 6bbl pan & fresh air air-cleaner w-phenolic spacers.JPG 68 RR #36 479ci Fuel reg. fron to engine rad etc..JPG 68 RR #37 Power Steering Pump for Unisteer rack & pinion serpintine belt acc..JPG 68 RR LL1 10-29-2017 #1 DS frt.JPG
68 RR LL1 10-29-2017 #2 DS rear.JPG 68 RR LL1 10-29-2017 #3 PS rear.JPG 68 RR LL1 10-29-2017 #4 PS frt.JPG 68 RR LL1 10-29-2017 #5 frt hood.JPG
Sorry about some of the photos quality, I'm no photographer...
Comments
Just a suggestion, :) not sure what kind of camera you're using and maybe photos of your car aren't important to you, but if you want better results, shoot your photos later in the day, not when the sun is directly overhead. Are you shooting in automatic? Try the manual setting and correct the F stop and shutter speed. That is a beautiful color, just overexposed.
thanks
It was just freshly painted
it was the 1st sunny day, after I could finally get it out
& yes it was mid day Oct. 29th 2017
I was impatient, I didn't care
I don't really care or know much about photography
& I'm not a photographer, I don't/won't spend much
on it either....
Obviously....
I just wanted a shot of the car outside, finally...
I go thru cameras like socks,
most are cheap digital throwaways too...
thanks for the suggestions
It might be possible to correct the exposure in the computer if you have a program. I like taking a lot of photos of my car as I work on it and finished. I can tell it's midday because of the shadows. Just a suggestion, not important.
Item information
Category
FBBO Member Photo Garage
Added by
Budnicks
Views
7,784
Comments
43
Last update
Rating
5.00 star(s) 6 ratings
Share this item
