Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hi kraig, I made the light out of diesel truck trailer stop, turn, brake lights. There 7 x 2 in. Red led lights that run on a straight 12 volt, no relays needed. Hard wire into existing tail light wires. Mounted in buckets with dense foam to hold in place. About 40 dollars and 2 hours start to finish. 10 times brighter then reg. Lights and a lot cheaper then custom led lights. Go to a truck stop or a truck store that sells led lighting.
