Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
great work,how did you determine where to make your cuton the qtr panel,how far did you come down before you marked your cut? i have to do the same. thanks
Thanks!
I overlapped about 1/2" for temp placement (you can see 2 cleco pins in the middle of the panel in last pic), then I traced the top of the new qtr edge onto the green tape on what's left of the original panel. Just before final welding, I trim back on the line & use the 2 clecos at the ends (taillight bucket & door jamb) to hold it, & use magnets to line up the edges (& lots of Vise-grips along the bottom edges...). The seam is ~ one & half masking tape widths (~1-1/4") down from the corner.
Hope this helps.
