Budnicks 68 RR LL1 Surf Turquoise Metallic
About this Mopar:
Still far from done, still need cut & buff
{garage paint job, far from show quality}
BUT;
It's got some color, the engine bay is kind of old & dull
the rest is the OE LL1 Surf Turquoise Metallic
don't mind the date stamps this was 10-2017
I'll add some full photos when I get it out in the sun...
Latest 1st time out in the sun
still no cut & buff 10-29-2017
never mind the date/time stamp this was an hr or so ago
Oct. 29th 1:00pm
STILL Not finished, but I figured I would share a couple more of photos,
The B_I_T_C_H as she's know 63,000 {now has 67k 10-2013} original miles
She was under a tree for 10 years in Sacramento/Rio Linda area
& had a 3" deep crease down the drivers side when I got it...
Outside is some what stock appearing with a A-12 6bbl lift off pinned hood
& Polished Edelbrock/Halibrand Kidney Slots
15x7 & 15x9 with 245/15/60 BFG Ta's & 295/15/50 BFG Ta's.
68 RR HT 383 auto 0.040" over 4.290" bore,
ARP 12 pt. &/or stainless hardware everywhere, tons of aluminum stuff,
Edelbrock RPM heads, MRE Custom rad, MP Alum water pump housing
& Pro-Comp electric 38gpm pump, MP cast polished valve covers...
Custom Crane Hyd. Roller camshaft & Retrofit lifters, 1.6:1 Super Gold roller rockers...
3" mandrel bent Flowmaster exhaust, Delta 50 Racing series mufflers,
with H-pipe, 3" tailpipes all the way out the rear...
OS Hellwig sway bars 1-3/8" front & 1" rear...
{currently 3.23:1}
Unisteer rack & pinion steering, Edelbrock IE Gas shocks
& SSBC Force 10 disc Brakes...
Original Black Decore interior & Scat-ProCar Elite 1100 series Bucket seats,
Tuff GT wheel, custom Painless 4 switch panel & complete electronics
on a custom relay panel system...
Soon to be a custom gauge panel {see below}...
MP chrome ignition box & adj. vac. adv. MP CEI distributor, new ign. curve,
dual electric BeCool fans 16" 2950cfm puller in a custom alum. shroud
& 13" 2650cfm pusher...
All Aeromotive S/S 175 gpm Elect. fuel pump,
Quick Fuel in the Center 2300 carb & Promaxx performance parts
& adj. jet plates in the outboards, Holley 6bbl set-up,
HP 50cc pump & different springs in the outboard carbs,
New fuel system, new fuel tank, sending unit
& #6 AN feed & #4 AN return lines, Aeromotive bypass style fuel reg. & gauge...
![i9678.jpg i9678.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/253/253323-153733a001153607a1e32e2cc9144033.jpg)
![i9683.jpg i9683.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/253/253328-8b5c8d73ca90654ddda7914ed66bef1d.jpg)
![68 RR #30 A-12 6bbl pan & fresh air air-cleaner w-phenolic spacers.JPG 68 RR #30 A-12 6bbl pan & fresh air air-cleaner w-phenolic spacers.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/334/334503-37162055cc53821b67fea118b03a9a54.jpg)
![68 RR LL1 10-29-2017 #2 DS rear.JPG 68 RR LL1 10-29-2017 #2 DS rear.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/461/461926-8aa6f79f0c5ebdd2dc45f67c1f1c77ad.jpg)
![68 RR #27 479ci-6bbl.JPG 68 RR #27 479ci-6bbl.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/334/334502-0a1e107cba00995b48165dbf5fd73086.jpg)
![68 RR LL1 10-29-2017 #1 DS frt.JPG 68 RR LL1 10-29-2017 #1 DS frt.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/461/461922-a47b1c283b9b233e573dc324736396cc.jpg)
![68 RR LL1 10-29-2017 #5 frt hood.JPG 68 RR LL1 10-29-2017 #5 frt hood.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/461/461929-a88ceb5f74ffdca0090024d5a53449c3.jpg)
Sorry about some of the photos quality, I'm no photographer...
BUT;
Oct. 29th 1:00pm
{currently 3.23:1}
![i3883.jpg i3883.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/248/248799-0291178a0bbce5c672b5ead4a4f752d4.jpg)
![i3884.jpg i3884.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/248/248800-4312ac9e4f83a71ca0b7a1db363eb613.jpg)
![i3886.jpg i3886.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/248/248802-452bd49d7e0415da8a53bf8957c8295d.jpg)
![i9679.jpg i9679.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/253/253324-8aea4985dd52e3b948e287d79e63f3ba.jpg)
![i9681.jpg i9681.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/253/253326-227d39e1a9e0fc556a0180848620e29e.jpg)
![i9682.jpg i9682.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/253/253327-58359f1d3bbf35c2109d728887831945.jpg)
![i10317.jpg i10317.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/253/253813-e2ec4eb7fdff88d2fadd7e34c10eca2d.jpg)
![68 RR #29 479ci-6bbl #6 AN lines & phenolic spacers.JPG 68 RR #29 479ci-6bbl #6 AN lines & phenolic spacers.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/334/334501-f0c939263d6d3ef46eb890e8677ea60a.jpg)
![68 RR #36 479ci Fuel reg. fron to engine rad etc..JPG 68 RR #36 479ci Fuel reg. fron to engine rad etc..JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/334/334504-d200f8f35335e039b1848039d506982f.jpg)
![68 RR #37 Power Steering Pump for Unisteer rack & pinion serpintine belt acc..JPG 68 RR #37 Power Steering Pump for Unisteer rack & pinion serpintine belt acc..JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/334/334505-143b0c238311fefdb65eb3b02a456756.jpg)
![68 RR LL1 10-29-2017 #3 PS rear.JPG 68 RR LL1 10-29-2017 #3 PS rear.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/461/461927-bd312704a3c61f4fb98d4ff12eb0b04a.jpg)
![68 RR LL1 10-29-2017 #4 PS frt.JPG 68 RR LL1 10-29-2017 #4 PS frt.JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/461/461928-edbd7efd00479e1d6177ff1858db961d.jpg)
