What is the possibility of Cragar 15" rims from a jeep cherokee fitting on a 71 Charger ? Actually I believe they are 15x8. 3.75 back space and 3.25 bore, 5x4.5 bolt pattern
93-98 Cherokee was 5 hole, 4 1/2" bolt circle. 1999-2023 they were 5 hole, 5" bolt pattern.What is the possibility of Cragar 15" rims from a jeep cherokee fitting on a 71 Charger ? Actually I believe they are 15x8. 3.75 back space and 3.25 bore, 5x4.5 bolt pattern
They will fit. They really are not a car wheel by appearance. More fitting for 4WD applications.These are the wheels. Summit doesn’t show 71 charger in the fitment chart…. Maybe a bad sign ?
Cragar 1521395014B Cragar Black V-5 Wheels | Summit Racing
They should. But like any wheel you never know.It is a set of 4. Will they work on the front too ?
Well, I bought them. They are in almost new condition. $100 for the set of 4. I think $ 25 each is a good enough price to experiment. The idea is 275/60-15 in back and 235 or 245 up front. I do have 1 inch spacers for the front if needed. We will play with it when I am cleared by my Dr for working again, still on concussion protocol. My wife and seller put them in the car for me.
But see, that's the thing! It's all about backspacing! If you have the right backspace, you can fit big tires. If you don't, you can't.My 72 had 15x8 Keystones with 265 50 tires in the back.
They fit fine, but I don't remember the backspacing.
They actually looked perfect in those cavernous wheel wells.
