15x10 Cragars...
TommyShameless1978
11:24 PM
Florida (unfortunately...)
Hey guys, I need 2 15x10 and 2 15x8 Cragar S/S rims for my 68. I know that the 15x10's typically come in 4.25 inch backspacing, which will work, but I think 4.75 or 5 inches would be ideal. Anywhere around there will be fine. Standard backspacing will do fine up front with the 15x8's.
I am located in Florida. Local is better, if possible.
Tommy
Tommy, Have you test fit a 10" rim on your car? No way a 10" rim with 4.25 bs will fit. Also 15x8's in the front may cause teuning clearance problems.
Your safe bet is 15x8 for the rear and 15x7 for the front. Good luck
I forgot to mention that I am re-arching the leaf springs to 4 inches over stock height. The nose is gonna be a bit higher than stock, as well. I hate the way these things look when they sit low. I know, I know, it goes counter to what everyone else here does, but hey, it won't have the nose-down stinkbug stance, and I'm not doing it with shackles or air shocks.
