FOR SALE 1966 Belvedere
Shenango
5:23 PM
Saegertown, PA
The Belvedere. A++ condition driver quality. Non original mild build J code 440. .509/.292/108 cam, 727 trans with shift kit, Edelbrock performer 440 intake, 906 cast iron heads, Holley 3310-3 carb, no name headers, power steering new conversion last fall, manual drum brakes all 4 corners, new build on differential last winter with 3.55 gears all seals and bearings and u-joints are new. 2 year old Firestone tires 255/60/15 rear 235/60/15 front. Included in sale is a Wilwood disc brake conversion for the front. Wilwood dual master cylinder, Cast exhaust manifolds with gaskets, manual steering box. This Belvedere has all kinds of fun built into the engine and transmission. The engine is cooled by a Champion radiator and will stay at 180*all-day long while cruising. It also has an electric fan, controlled by a switch in the console, to use at Burger King if the temp gets close to 200* while waiting in line. The floor pans and trunk pan are rust free, the PO put frame rail connectors in and I extended the exhaust over the rear axle and out the back this year. If you need a true turn key, hot rod, B-Body this is the one you are looking for
I am asking $34,000. Local pick up only....Car is located in Saegertown PA. 16433
