FOR SALE 1970 383 engine $1400
NTOLERANCE
2:58 PM
Madison, WI
Feedback: 2 / 0 / 0
$1400
Low mile c body engine, was a running engine when pulled. Not an HP block ( Car long since scrapped )
Stock bore, pistons crank and rods
New bearings, rings and seals
New vintage 1980's Erson TQ50 cam shaft
New vintage - 1980's crane lifters
New new double roller timing chain
16 new hp replacement valve springs
12 new valve retainers, I have some used stock ones available as well.
One used windage tray
One like new Carter hp mech fuel pump
I have a couple of stock timing covers to choose from as well as a stock balancer
346 heads, with fresh valves, valve job, viton seals, bolted to an engine but never run. This cost $700
Weiand 8008 dual plane intake
Modified deep sump oil pan and pick up.
Mallory unilite distributor.
Please note that the springs and aluminum retainers currently on the heads are not included, I just used them to keep the valves in place. (You don't want to use them anyway )
No push rods, rockers, hold downs, water pump.
$1400
Pick up near Madison WI. 53589
I don't see a price. Please edit it into your ad. Thanks
