SOLD 1970 727 Transmission
Dave6T4
2:04 PM
Ontario, Canada
1970 Big Block 727 transmission. Internal parts and case # decode to use with 383HP. The # on the case is PK3410 6681 3141 0521. The transmission mount tells me this was originally in an E-body, but the transmission would also be correct for SuperBee or RoadRunner. Has been totally rebuilt with A&A Transmissions rebuild kit and parts. Factory installed HP parts include 4-clutch drums, front and back, 3.8 ratio kickdown lever, single kickdown servo spring, 6 springs in in front clutch piston, and 4-gear front planetary. I have upgraded with 5 clutches in front drum, shift kit, and part throttle kickdown. Rebuilt with new gaskets, seals, bushings, sprag rollers and springs, clutches, filter, and front band. Comes with factory Hi-Stall torque convertor, which has been drained and flushed. I am sure that no one has been inside this 727 before me. I have been building 727's for almost 40 years, and this is one of the cleanest, nicest ones I have seen. Cannot ship. I am in Ontario on the northern shore of Lake Erie, midway between Buffalo and Detroit (postal code N5H 2R2). $1100.00 U.S.
What is the partial vin on the right side of bellhousing
Looks like 0E239535 . It is pretty faint, hard to make out.
