1970 Rallye dash/cluster into 1969
rp23g7
2:05 AM
Lynnwood, Wa
So, I have a chance to buy a Rallye dash frame and cluster from a 1970 Satellite.
Will a 70 Rallye frame fit in a 69 Coronet?
are you sure its a ralley cluster ???? a 70 satelite would have had just a standard cluster ? plus in 70 they went to the key in the column so no place for the key in the dash and no switch for the hazzards on the dash .
HMMM, good question. One of the new guys in MU-Seattle, has a 70 Satellite/Road Runner clone.
He may have meant he has a 69 Rallye and it wont fit in the 70 due to those reasons. I will check.
Just get a reply, he stated its a frame and cluster out of a 68 Charger.
did you have a ralleye to start or the rectangle style because i believe the two have a different wire harness which unless you can find used your looking at around $500 for that
I have the rectangle dash, but his is giving my the frame, insert and wiring also
