1970 Road Runner Six Pack Fuel Run Off Issue
RoadRunner1970
6:47 PM
USA
I am having an issue after filling up the car with gas and parking it in the garage, fuel overflows from gas fill. Is this a venting issue, I am using a non vented gas cap. Wanted to get other peoples thoughts on this issue. thanks
Fuel expansion, cold fuel out of a ground tank and you park it in a nice warm garage.
Is it actually leaking out the cap or from around the rubber tank to neck seal that generally rot after 50 years..
You also should make sure that the actual vent tube is intact and not plugged.
I was curious if anyone else with the six pack setup with the vapor separator is having this issue? Thanks Brian
