1970 roadrunner air grabber switch mounting location
barryv
6:10 PM
middleburg,fl
hi, does the air grabber switch mount from the back side of the dashboard or outside of dashboard? thanks
Bezel screws to the dash plastic
The switch is fixed to the dash steel frame.
If you don't have a hole already, then you should be able to feel behind the dash frame for the location.
It's a 22mm (7/8") hole from memory. You will have to drill the plastic dash cover.
After making hole, does switch get mounted from backside of dash? Thanks
Yes, switch on the backside and the switch bezel on the outside where two trim screws (I believe) hold it all together. I've had to research this as well since I added the airgrabber hood to mine, but I temporarily mounted the switch in the glovebox so I still have all this to do myself.
thank you, i had mine mounted outside rather than backside. thanks for the info
