///Matt
I have 2 good cores for refurb.
One came out of my ‘68 sport sat. has a 1567 date code on it. It needs cosmetic refurbishment, and the speedo is definitely bad, needs a rebuild. The other gauges worked when last installed. The clock does not work, and is currently not installed.
$120 shipped in the 48.
The other is out of a ‘69 sat sedan. Has a 1469 date code. No clock/no Tach cluster. It is cosmetically nicer than the ‘68, but I cannot make any claims about any of the guages working, as the car has never run in my possession... but it came from a car with 54k original miles, so I’m reasonably confident that the gauges other than the speedo function, and no opinion about the speedo.
$150 shipped in the 48.
With either of the clusters, what you see is what you get. I do have one set of hardware to mount the cluster available for an additional $5.
