70B5Cuda
I bought this 1969 Belvedere from the original owner in my home town. The title was the original issued in 1969. The car had not been on the road since 1988-off road for over 20 years. It was ordered with 383, automatic transmission, and 2.76 Sure Grip 8 ¾ rear end. Air conditioning was added by the dealer. Apparently very few people ordered Belvederes with the 383 (biggest available for that model) as it is one of just 33 1969 Belvederes ordered with the 383. It has its original numbers matching engine and transmission, which have never been out of the car. It is an original 2 barrel car but I will include a period correct 4 barrel intake that I bought, stripped, and painted. Since purchasing the car from the original owner, I have flushed the fuel tank and fuel line and replaced the in tank filter, inline fuel filter, fuel pump, spark plugs, spark plug wires, cap, points, condenser, valve cover gaskets, valley pan gasket, and exhaust gaskets. I also had the carburetor rebuilt. I rebuilt the brakes by replacing the master cylinder, all four wheel slave cylinders, brake pads, right front hard brake line, and right front soft fuel brake line. I had the radiator hot tanked and repainted and I replaced the thermostat, water pump and water pump housing. I stripped and repainted the water pump/pump housing, valve covers, intake, and air cleaner housing. The paint is at least 25 years old but I was very surprised how nicely it cleaned up. It is a good complete driver. The quarters have some small rust spots coming through and the floor has some rust issues. The trunk is quite solid with some small rust in the middle of the trunk pan in the lowest valleys where water sat. There are typical dings and scratches as would be expected from a car this old. Some old filler is cracked on the right quarter-it is a repaint that was done in the late 70's or early 80's. All the glass is good and windows work as they should. The exhaust is complete and quite-with no leaks, which is surprising. The air conditioning and windshield wipers don’t work. The tires are fine for running around town but they could use replacing. You can have your choice of the Mopar road wheels pictured or the original body colored steel wheels and hub caps. I just use this car as a run around town car and it has been a blast to drive. However, I have 5 cars (3 Mopars) and need to thin the herd. I have a clean Kansas title in my name and the Broadcast sheet (which is now laminated to preserve it). Fender tag is still in place on the fender. Email me for more pictures. $6800 obo. Thanks!
