69 Coronet R/T. 3:54 Dana 60. New green rear wheel bearings. Neutral and not under load. Does not increase when turning wheel right or left. Constant and consistant with road speed. Front bearing are next and would like advice before going through the Dana which has been bulletproof since car purchased in 1988. Changed the dana fluid about 5 years ago. Drained brown river water out, put synthetic ina nd it leaked in 100 miles. Changed it again and replaced the seal.
WHat else could it be. It has been doing it for about 900 mmiles with no other symptoms or increase in sound. Sounds like a classic wheel bearing problem, not sure but seems to be on the rear of the car. Right now I am ignoring and driving to see what happens. Need a fix or at least a dignosis befor going to Fall Fling.
