295/50/15295/60/15 or 295/50/15?
Then I think there could be a problem. The 8" rim pulls the sidewall in a little bit. 8" is the minimum u should go with but I've seen guys use 7's.Wonder how much wider the tires would be on a 10" rim?
That's what I was thinking. I can fit 295's with a 10" rim on my 69 Road Runner, but they are tight. A lot less room than you have with the 8" rim. I wasn't aware an 8" rim was recommended for a 295 tire, but then I know of a guy who runs 275/60's on a 10" rim which isn't listed as being ideal either.Then I think there could be a problem. The 8" rim pulls the sidewall in a little bit. 8" is the minimum u should go with but I've seen guys use 7's.
